Remove Element Register Event Callback
Hi Ppl,
I had a previously written code having Reg Event Callback Node. I had to delete few events in that code. So I disconnected the event refernce, VI refrence and user parameter inputs. When I right clicked on the node that I wanted to remove I couldn find the remove element shortcut that could be found in bundle, unbundle cluster, register events node.
There are a large number of callbacks registered in this node. So It will be very tedious to delete all the callbacks below this event and rewire them.  Is there any shortcut to do this. I have attached a small screen shot depicting my problem. I guess its a silly question. Expecting your comments.
(4,351 Views)
Is there a way to delete the elements in the register event callback node or should I have to rewire the entire code ?
(4,330 Views)
Unfortunately, the only way to remove events is to resize the Register Event Callback. The resize can either be done from the top or the bottom.
(4,323 Views)
Ho... Thats very bad. Is there any chance that this will be added in future versions of LabVIEW ?
(4,321 Views)
I guess you can not delete a particular property. So you have rewrite the code. So while rewriting you can create only one property everytime.
Also why dont you post this in the Idea zone so that this gets implemented?
Regards
Guru (CLA)
(4,319 Views)
