Remove Noise
Let me first explain my problem,
I have a data acquisition card, taking input at 22050 samples/sec.
But after every 9300 samples or 488 msec (approx.)(see attachment) some noise is coming, i.e. in 1 sec (22050 sam) the noise repeats itself twice.
I think the problem is with  hardware, that we trying to sort out.
but i have given the job to solve it with software.
With help of signal generator, i have given 100mV, 100Hz sine wave input, that i have recorded as wav file.
By reading the wav file you can see the signal and noise seperately, respective VI is attached.
Is there a method to remove it.
Message 1 of 11
(6,324 Views)
What is the cable length you are using? Can you shorten it and try?
Message 2 of 11
(6,317 Views)
Hi MUKS,
Thanks for quick reply,
The cable length is small , about 15 cm, then also i will try to shorten it.
Message 3 of 11
(6,313 Views)
Hi again,
I am connecting the card through the USB port, so i tried by connecting the card directly through USB port, then also the noise exists.
sound nt
Message 4 of 11
(6,309 Views)
The Labview sound system introduced in 8.x has some flaws that NI has ignored for a long time. I think your problem is in the recording part of your program. Can you post this code
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 11
(6,286 Views)
I didnt do much, just used the VI given in the Examples. (Sound input to file).
But i have some other programs which detect the card and take input then also the noise comes.
Cant there be any method to eleminate the noise.
Regards
Message 6 of 11
(6,272 Views)
Have you done any changes to this example. If so please post it
Message 7 of 11
(6,259 Views)
Can you give more details about the exact hardware that you are using?
Message 8 of 11
(6,253 Views)
Coq Rouge  : No i have not made any changes in the example.
  : I am using a audio ic which can take analog input and can sample at 44 ksps.
Message 9 of 11
(6,245 Views)
You can try the modifications I have made. I used constants just to show the value. The Labview sound system may create errors then reading data more than once every second.
Message 10 of 11
(6,235 Views)
