Remove Serial Header Rs 232
I need to remove the header from the serial data pack being sent by my Labview PC using VISA through a COM port.  I am using a simple 8N1 packet.  Is there a property I can change so that only the data bits and stop bit are sent?
I have attached my VI and an image of what the oscope capture looks like.  In this case I am sending 0x72 to be received by the test unit.
(2,539 Views)
duplicate post, already continued here!
(2,529 Views)
