Remove checksum from each line of array
Hallo
I have output as Array and from that I have to just read out the data with out check sum
I.e., I have to neglect last 2 Bytes from each line of array . I tried many time but I cannot succeed . It would be kind if anyone help me to get ride out of this problem.
thanking you
Best Regards
Kalu
(2,437 Views)
Accepted by topic author kalu
Hi kalu,
you really tried "many times" to remove the last two chars from each string? Using an autoindexing FOR loop?
(2,429 Views)
Thanks GerdW
it really work. You are simply great.
(2,421 Views)
