Remove context menu from standalone executable
When I build a stand alone executable from within LabVIEW all controls of the application contain a context (right click) menu (Cut Data, Copy Data, Paste Data, Description and Tip, ..).
Is it possible to suppress this menu?
(3,951 Views)
Yes, it is possible.
Select File->VI Properties->Window Appearance->Customize...
And then uncheck option "Allow run-time shortcut menu"
(3,951 Views)
Hi Ralli,
Adding an event case to check for a right-mouse button does the trick provided you discard the event only when the right button is used (See code).
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,951 Views)
You can use the Tools>>Properties dialog to disable the shortcut or
right-click menu. You can also directly enter this into the .ini file
that goes with the exe.
Greg McKaskle
(3,951 Views)
