Remove diagram space inside structures not always working
When using the shortcut (ctrl + alt + mouse left drag) to remove diagram space, it sometimes happen that the VI completely forbids it inside structures for no apparent reason…
Actually I found a reason: when somewhere in your diagram, you have a loop with the iteration or conditional terminal (visible or not) colliding with a shift register:
After moving the iteration terminal away from the shift register:
(1,142 Views)
You should be able to resize the structure if you disable the autogrow's option as below :
Loïc
(1,037 Views)
That is an interesting bug you found there. It can be easily duplicated. I am using LV 20.0.1f1 (32-bit) to duplicate it. The iteration terminal must be at least one pixel on top of the shift register for the re-sizing not to work.
The overlap prevents other structures from being resized anywhere on the block diagram. The resize still works outside of the structures.
Former Certified LabVIEW Developer (CLD)
(1,011 Views)
