Remove fade from tank indicator
Hello everyone,
When you create a tank indicator or silver boolean, they are colored with a slight fade.
Does anyone know how to remove this?
Thanks.
(2,681 Views)
Accepted by topic author KeenanJohnson
For the Tank you can copy the background and the fill from the Classic Slide.  Customize the Classic Slide, change to tweezers, select the background, copy to clipboard.  Close and Customize the Silver Tank.  Again select the background and choose Copy from Clipboard at Same Size.  Repeat for the fill.
(2,669 Views)
Gotcha. Yeah i just figured there might be an easier way to do something that seems pretty simple. Thanks though.
(2,625 Views)
