Remove frame from indicator
How to remove frame from numeric indicator? I tried in "Modern" but cannot get rid of the frame. There is "System" indicator  but I cannot change the background color to match vi's background. Any ideas?
I put picture of what I need.
Zoran
(8,079 Views)
Accepted by topic author zoran
Classic >> Simple Numeric
Tim Elsey
Certified LabVIEW Architect
(8,075 Views)
And in order to remove the frame from the modern indicator, you use the paint tool and color it transparent. Make sure you select the frame by hitting the space bar.
(8,066 Views)
How do you select the frame? I was clicking all over it but couldn't select frame. I have LV8.6.
Zoran
(8,063 Views)
Just move the tip of the paintbrush over the edge of the frame and make sure the box on the left is highlighted as in the picture. You also can't do this with the system controls.
(8,059 Views)
Oh.  I didn't know you could do that.  I just played around with it for like 3 minutes and only successfully changed the color twice.  It's not very intuitive.
Tim Elsey
(8,054 Views)
