Remove old computer from labview license
If the question is: How do I deactivate a LV license if I've already wiped the disk (or it e.g. crashed)?
Then it can be a hassle. One solution (which technically violates the license) is to simply install on the new computer. As the old one won't be reactivated in the yearly check, it'll kind of 'fix itself' in a while. The issue here is 'over booking' of the license, not the actual installations.
The licensing department should be able to unregister any license though so I don't know what's up.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(1,254 Views)
You don't need to unregister anything.
As the license agreement explains, software can be installed at three computers at a time. That means once you uninstall it on one (deactivating is not enough), you can install on another.
It's also described here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7WFSA0
Message 12 of 13
(1,240 Views)
(When NI support directs you to the forum to discuss license issues then there is something wrong with NI supprt…)
It might have happened because of inactive service program.
I'd be more than happy to investigate that, if the author PM's me the service request number.
Message 13 of 13
(1,236 Views)
