Remove ".lvclass" from class property node
I have a class with data accessors as property node. Each property node has the full name of the class, including the ".lvclass" part. I think this is unneccesary as you are already passing in a wire associated with a class. Like this:
The property node is a lot smaller now, making the code cleaner.
I know you select "No name", but that remove all lables entirely. I'd prefer a middle-ground. Is there an optiont that let's me do this?
(1,642 Views)
Accepted by topic author Basjong53
Hi Basjong,
If you go into the class properties and documentation tab then you will find a Localized Name option. This is what gets displayed on property nodes so if you remove the .lvclass extension there, it will also be removed on the property nodes.
Cheers,
James
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(1,640 Views)
Wow, so simple! I can't believe I've missed that. I even looked through the class properties...
Thanks a lot!
(1,631 Views)
