Remove "toolkit expired" question- how to?
I installed a toolkit for testing. Then I removed it.
But I am still required to acknowledge that the "testing period has expired" on every launch of LabView.
How can I get rid of that question?
Cheers / Ake
(4,228 Views)
Which toolkit and how do you removed it?
Christian
(4,222 Views)
It is the Report Generation toolkit for MS office.
And I may in fact only have _tried_ to remove it (it was a while ago ;-), but did not find a way.
I expected the Launch Screen to also provide a button for "Remove Product" (in addition to "Activate Products" and "Purchase Products") but no... On the Installation CD I could neither find a means to "uninstall" a product.
Cheers / Ake
(4,213 Views)
Use Windows Control panel, go to Add/Remove Software, select National Instruments Software, and select the Report Generation Toolkit from the list which comes up then to uninstall it from your system.
Christian
(4,195 Views)
If that doesnt work you can use a msiblast
(4,172 Views)
