Remove repeated row in 2D array
Read the online help. 😄
(Quote: ... This function pads or truncates the data if necessary.  ... You also can use it to increase and decrease the size of a 1D array... )
The reshape function allows trimming and padding of arrays. you can also use the array subset function, for example. Same difference.
Message 11 of 12
(862 Views)
Thanks!!!
Message 12 of 12
(854 Views)
