Remove space from a tree control
In a tree control you can hide the symbols but the space for them remains. Is there a way to remove the excess space in the tree control? This will shrink the amount of horizontal space a tree control takes up on the front panel.
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Now also available on VIPM
(3,014 Views)
I don't think there is a way to show lower hierarchy items in the same position of an item in a higher hierarchy.
Perhaps you could add this to the ideas exchange, so R&D can have a visibility that you would like that to be possible. Here is the link.
(2,962 Views)
I couldn't find a way to do it, even digging into hidden properties.
(2,947 Views)
I suspected it wasn't removable. It bugs me that not showing the symbol still has a spot where it would go.
—Ben
Use Power Requests
(2,930 Views)
