Removing Frame of array indicator
I would like to Display an Array indicator in the front Panel without the Frame. For Color boxes there is e.g. in "classic" an unframed Color box. I couldn't find the equivalent for Arrays nor can I remove the Frame via property nodes.
Is there a way to do this?
Regards
(3,558 Views)
Accepted by topic author volfi
Hi volfi,
for sure there is a way!
Use the brush tool to color the frame transparent: check.png
(3,545 Views)
Use the Control editor and color segments transparent
(3,538 Views)
