Removing Noise
Hello everyone. We know that in PID control, the derivative part is highly susceptible to noise. I want to know how to remove this noise before starting my derivative action. The data rate which I'm getting from the simulator is at 20hz(same at which my loop runs). Let me know if you need any other info.
(3,926 Views)
Low pass filter.
Qestit Systems
Certified-LabVIEW-Developer
(3,904 Views)
Thanks for replying. But why not a highpass filter? I have an idea but the Exact reason?
(3,886 Views)
Noise is typically very ... noisy. If you do a FFT of a noisy signal you'll get frequencies over all the register. The signal you're interested in is 20Hz, which is a very low freqency signal. Technically you can do a 20Hz bandpass, but that'd get a little silly. 🙂
(Do that; create a white or gaussian noise signal and check its FFT) 🙂
/Y
Qestit Systems
(3,873 Views)
You want the D part to make the controller faster ... so the challenge is to still a D but seperate from noise...
So one method is to look back some more (use more past values) and try some fitting.
Use the last n (50?) values fit a square function and use that derivative at the endpoint?
Here is a link to some more methods
http://www.holoborodko.com/pavel/numerical-methods/numerical-derivative/smooth-low-noise-differentia...
LabVIEW has a Savitsky-Golay filter vi that can be used to get  low pass derivative coefficients for a FIR filter ...
Greetings from Germany
Henrik
LV since v3.1
(3,871 Views)
Thank you. What should be the sampling frequency the filters in labview ask?
(3,864 Views)
Thank you for replying. I partly understood what you said. My D controller is ready. I just want to remove the noise.
(3,863 Views)
