Removing a library URL network-publishhed source list
I've created a project library with an OPC client instance inside. When I deleted the project explorer files, all the VIs and library and all the files related to that project, I could see in the URL list of Network-published source binding a new control or shared variable in a new project, that library with its shared variable and OPC client instance already exists.
How a project can be removed thoroughly with all related files, URLs and DBs form a PC?
Thanks.
(2,607 Views)
Hi Maryam,
In order to undeploy the shared variable you need to goto the Shared Variable Manager. To do this open up LabVIEW goto Tools>>Shared Variable>>Variable Manager. The deployed processes will show up in the left had side of this window. To undeploy them right-click and select remove library.
Regards
Jon B
NIUK
(2,587 Views)
Thanks Jon.
(2,583 Views)
