Removing a list of indices from an array
" I must be doing an extra scalar copy or something."
I think you nailed it! Smiley Happy
I think your approach is moving two values were Christian is only moving one.
Ben
Message 31 of 40
(4,430 Views)
OK, I got an version with the "in place" structure, that is significantly faster. It can even do the 50M(!) I32 element array (200MB for a single copy)  in under one second. Even there, the time is still linear with the array size.
ArraySize        In Place Version
    5000        0ms|   0ms|   0ms
   50000        1ms|   1ms|   1ms
  500000        6ms|   6ms|   6ms
 5000000       67ms|  98ms|  66ms
50000000      678ms| 979ms| 649ms  (this is an additional data point!)
Maybe somebody understands why it is faster, or if it is even used correctly. 😉 Interestingly, I don't even read the element at the insert point, The index wire of the in place structure is just needed to define the insert point index at the right boundary. The other case is "-1" and just wired across.
(Btw, make sure to close the FP of all VIs under test. Having it open slows them down significantly.)
Message Edited by altenbach on 08-30-2007 11:58 PM
Message 32 of 40
(4,419 Views)
Sorry, I have to take that back.
If I replace the "in place" structure wuth a "replace array subset", I get about he same time, maybe even a bit faster. Originally, the "replace" version was slower than the "inplace" version only because I had debugging enabled by accident.
Message 33 of 40
(4,410 Views)
I see a problem with both of these solutions that use the in place element structure. You are both replacing elements in the array with -1 if they are to be deleted. However, what happens if the element is actually -1? I think you need to create another array, as Christian did in his original example, that contains all the indexes and replaces each of those elements with -1.
Message Edited by Marc A on 08-31-2007 08:52 AM
Message 34 of 40
(4,394 Views)
Christian,
I really appreciate the public service you are doing with these comparisons between old and new.
My gut feel is that LV was already damn good at minimizing buffer copies prior to the new constructs, PROVIDED you watched your buffer copies.
I suspect there was little room for improvement of the under-lying code but what ws improved was our ability to clearly designate what gets copied when. This by the way will be very helpful because the "old way" relied heavily on "gestures and inuendo (sp?)" to tell LV what to do with buffers.
Ben
Message 35 of 40
(4,390 Views)
Marc wrote "You are both replacing elements in the array with -1 if they are to be deleted. "
That thought crossed my mind as well.
If you read the fine print in an earlier post, they are exploring the special case were all values are positive so the "-1" flagging is valid for this special condition. Smiley Wink
Ben
Message 36 of 40
(4,389 Views)
Oh, ok. It's just that the other solutions handled it with the index array or even the boolean array. If the input to this sub VI is an I32, I should be able to put a -1 in the array. Once Christian gets here, he can have a little extra work. Smiley Wink
Message 37 of 40
(4,385 Views)
Yes, the "in place" structure does not give any advantage here, because the entire code is already "in place" anyway, so there is nothing to improve.
It should probably only provide an advantage in cases where the compiler is too careful and thinks it needs another datacopy, while you know things can be done in place.
Message 38 of 40
(4,373 Views)
Euh..  Wouldn't this topic be a very nice nugget???
(or did I miss that somewhere!!)
Message 39 of 40
(4,358 Views)
Good observation Ray.
Why don't you link this thread into Darren's "New Feature Nugget" as an apendix?
Ben
Message 40 of 40
(4,352 Views)
