Removing an Unintentional Serial Break
I have a RS-232 connection to a development platform and I'm using a Labivew connection to automate a test.  The test mostly works, but every now and then, I get a serial break in my communication which locks up the development platform (serial break is not used in the final application).  I do not have a serial break vi in my program.  What whould be generating this unintentional break?
5758       0.00002995          GTM4G V2.exe IRP_MJ_WRITE Serial0   SUCCESS              Length 9: 10 AA 03 C5 38 22 34 10 03
5759       0.00000124          GTM4G V2.exe IRP_MJ_FLUSH_BUFFERS            Serial0   SUCCESS
5760       0.00000143          GTM4G V2.exe IOCTL_SERIAL_GET_COMMSTATUS        Serial0   SUCCESS
5761       0.00000106          GTM4G V2.exe IOCTL_SERIAL_GET_COMMSTATUS        Serial0   SUCCESS
5762       0.00000195          GTM4G V2.exe IOCTL_SERIAL_PURGE   Serial0   SUCCESS              Purge: TXABORT TXCLEAR
5763       0.00000411          GTM4G V2.exe IOCTL_SERIAL_SET_BREAK_ON Serial0   SUCCESS
5764       0.00000379          GTM4G V2.exe IOCTL_SERIAL_WAIT_ON_MASK              Serial0   SUCCESS
5765       0.26961526          GTM4G V2.exe IOCTL_SERIAL_WAIT_ON_MASK              Serial0   SUCCESS
5766       0.00000165          GTM4G V2.exe IOCTL_SERIAL_GET_COMMSTATUS        Serial0   SUCCESS
5767       0.00000116          GTM4G V2.exe IOCTL_SERIAL_GET_COMMSTATUS        Serial0   SUCCESS
5768       0.00000114          GTM4G V2.exe IOCTL_SERIAL_GET_COMMSTATUS        Serial0   SUCCESS
5769       0.00000275          GTM4G V2.exe IRP_MJ_READ   Serial0   SUCCESS              Length 8: 10 15 02 AA 00 3F 10
Ryan
(3,075 Views)
What kind of instrument are you connecting? Have you tried communicating to this instrument using other software, does it lock up the same way?
A. Zaatari
(3,057 Views)
The instrument we are talking to is a consumer electronic device still under development.  The code in this device is not setup to handle the breaks.
(3,050 Views)
I am not sure why you would get a break, can you post your vi for further investigation?
(3,036 Views)
(3,023 Views)
You are sending numerous serial breaks in your program. They are not unintentional at all. Have you read the help for the VISA Clear?
(3,016 Views)
