Removing block diagram
Is there any way to remove the block diagram on a single file basis (just like in the old good LV 7) without creating a source code distribution project?
I'm trying to create hook scripts for SVN and I'd like to remove the Block Diagram before publishing my code..., I'm using LV8.2.1 and will be moving to 8.5 soon
Please help!!!!
<<N>>
Message Edited by << - N - >> on 04-08-2008 11:09 AM
(3,675 Views)
Hi <<N>>,
i´m not sure how it works in LV7, but in 7.1 you can use the "save with option" function and select remove block diagram.
Mike
Message Edited by MikeS81 on 04-08-2008 08:14 PM
(3,671 Views)
Hi Mike,
I think they work the same way in both 7.0 and 7.1 but in 8.2 and 8.5 there is no "Save with options" and the only way to do this seems to be creating a project...
Hopefully this functionality is 'hidden' somewhere otherwise I won't be able to create my script =S...
Does anyone know if this is possible for LV8.2/8.5???
Thanks for your help !!!
<<N>>
Message Edited by << - N - >> on 04-08-2008 01:53 PM
(3,644 Views)
Looks like the "Save:Instrument Method" will do it, it actually works like in previous versions; they just removed it from the 'File' menu
(3,637 Views)
