Removing cluster element from XML, instead of replacing with blank
So I want to remove any empty values from an a cluster.
In my example I have.
Cluster called -> Media List
This contains an array of:
-> Media Name
-> Media Path
I want to remove any of the empty medias from the xml
at the moment, I'm just indexing it in a for loop and replacing it with an empty constant but this doesn't actually do anything I realised, it's just re-placing the empty value.
What's the proper way for me to delete this element? Thank you
(1,066 Views)
Accepted by topic author TylerHW
Hi Tyler,
Let me reformulate your statement to be sure I understood it correctly:
I have an array of clusters (representing a list of media) on which I want to remove all elements that have an empty "Media Name".
Simply use a conditional auto-indexing tunnel. This will keep only elements that satisfy a certain condition (in your case having a non-empty Media Name):
(1,037 Views)
