Removing different items/Folders from LV Project
Typically, when I want to remove a vi or virtual folder containing vis or something from a project, I just right click on it and select "Remove from project"...
I want to understand why it seems some things cannot be removed from a project this way-
If I right click on an auto-populating folder I do not see any option that would remove or delete that folder from appearing in (or being a part of) the project.
Likewise if I try to go down into that auto-populating folder, it won't let me remove from project (although this I understand because by the very nature of putting something in that folder you want to have it be a part of the project right?).
What am I missing here?   I'm guess there's some kind of simple explanation I'm missing...
Thx
-pat
(2,427 Views)
I hardly ever use auto-pop folders, but I happen to have a project which has one open at the moment (in 2011) and when I click it I do get the remove option (at the bottom of the menu). The folder has other folders in it and for those I don't get the option, but that's just the same as the other things in the folder and you already pointed out why that happens.
___________________
Try to take over the world!
(2,402 Views)
