Removing non-alpha-numeric characters from a string
How can I remove all non-alpha-numeric characters from a string? (i.e. only alpha-numerics should remain in the string).
Message 1 of 25
(28,487 Views)
Like this?
___________________
Try to take over the world!
Message 2 of 25
(28,485 Views)
Or even without a loop ?
Extract from the help for the Search and Replace String function :
Right-click the Search and Replace String function and select Regular Expression from the shortcut menu to configure the function for advanced regular expression searches and partial match substitution in the replacement string.
Extract from the for the advanced search options :
[a-zA-Z0-9] matches any lowercase or uppercase letter or any digit. You also can use a character class to match any character not in a given set by adding a caret (^) to the beginning of the class. For example [^a-zA-Z0-9] matches any character that is not a lowercase or uppercase letter and also not a digit.
Message Edité par JB le 05-06-2008 01:49 PM
Message 3 of 25
(28,472 Views)
Yep, that looks better. I happily never had the need to use regexes too much, so the less I know about them the better. Smiley Wink
___________________
Message 4 of 25
(28,454 Views)
I'm ever again astonished by these string format specifiers ! So compact and powerful ! So easy... once the code works ! And at the same time so incomprehensible unless you are very familiar with them !
Get File Extension.vi (Functions palette >> File I/O >> Advanced File Functions) with its \.[~\.]*$ format specifier is a good example.
Message 5 of 25
(28,450 Views)
Yes, but I was always one of those who go with the feeling that languages like Perl look like an explosion in an ASCII factory. Having to decipher those hiroglyphics is not that much fun.
___________________
Message 6 of 25
(28,440 Views)
You folks should try to spend some time with bash scripts and grep. Your heads will start spinning, as mine has on multiple occasions. Smiley Very Happy
Message 7 of 25
(28,420 Views)
I would recommend to recruit the "lexical class" tool from the comparison palette for this, it can simplify your code quite a bit.
You want lexical classes 3,4, and 5.
Check the online help.
Message 8 of 25
(28,414 Views)
Does that mean that once you have the Lexical class/classes you can filter strings with them?
Craig
LabVIEW 2012
Message 9 of 25
(28,410 Views)
Here's a quick draft that would do the current problem.
EDIT: This is ancient code and the conditional tunnel did not exist when this was posted. In modern LabVIEW versions one would use a conditional tunnel and "in rage and coerce", eliminating the shift register and case structure. .
Message 10 of 25
(28,405 Views)
