Rename name of tags in OPC server.
Hi, everybody. I try to find answer to my questions, but don`t find.
I work with NI OPC. just now I create tags in interface of OPC, also rename tags in interface.
But now, I want to create tags, or rename existing tags programmly, i.e. in LabVIEW code. Is it possible? I use LabVIEW 2010.
(3,306 Views)
Hi rusl,
Do you have NI LabVIEW Datalogging and Supervisory Control (DSC) Module? If so you can use the following.
http://zone.ni.com/reference/en-XX/help/371618F-01/lvdsc/open_tag_readerc/
Josh B
(3,291 Views)
Hi Josh B
Can you give example, how Open Tag Reader.vi can help me to rename some tags? I try it, but can`t find solutions.
(3,281 Views)
Hi rusl,
What versions of NI OPC Servers and LabVIEW Datalogging and Supervisory Control Module do you have?
Josh Brown
(3,273 Views)
NI OPC SERVERS v.4.500.462.0-U
LabVIEW DSC 2010
(3,263 Views)
Accepted by topic author rusl
Hi rusl,
This is actually not possible. The NI OPC Server is acting like a client so the tags cannot be pragmatically changed from LabVIEW. Sorry for the incorrect information initially.
Josh B
(3,248 Views)
Thanks for information.
(3,235 Views)
