Rename the folder "volume" for the Setup.exe into "Installer" (LV 8.5)
Dear All,
How can I rename the "volume" folder for the Setup.exe into "Installer" or what ever automaticly under LV 8.5
cu
Daniel
(3,255 Views)
Hey,
Is this folder from an exe of yours or is it from another installer?
Christian
Message Edited by Christian_M on 01-17-2008 09:59 AM
(3,236 Views)
The folder is made by LV 8.5 during the installer build process.
A your are a certifyed lv user? LV is not bad for share ware!!!
(3,230 Views)
Hey,
No, it's not possible to change the subdirectorys, only the root path for the installer within its configuration.
Christian
(3,223 Views)
"No it´s not possible" .... that´s how LV 8.5 works.
I like it ! NI is the best, if you don´t want to work with it.
cu
Daniel
(3,220 Views)
Das ist nicht gerade eine qualifizierte Aussage.
Dennoch könnten Sie die Advanced File I/O Funktionen nutzen um sich schnell ein VI zusammenzubauen welches genau diesen Ordner innerhalb eines Stammverzeichnisses , so wie Sie es ja anscheinend angelegt haben, in den gewünschten Namen ändert.
MfG
Message Edited by Christian_M on 01-17-2008 11:12 AM
(3,215 Views)
