Renaming boolean array text
I'm trying to create a Boolean array of checkboxes with each element having a different text associated with it.  Unfortunately when I change the text of one element, all other elements also change to that name.  Attached is a screenshot of this behavior.  Is there a way to make it so each one of the checkboxes can have a different text associated with it?
(3,075 Views)
Array elements must have exactly the same property values.  If you want to display a bunch of checkboxes with different text, use a cluster.
-D
(3,069 Views)
