Reopen avi file
I am doing time laps video.  I create an avi file.  Periodically I write to it.  At the end I close the file.
If the program closes unexpectedly/ungraciously all the video is lost.  Most unhappy.
I got the bright idea to close the file and then re-open the avi file.  Snake-eyes.
Is it possible to append to an avi file? I would have thought so but you never know...
(4,181 Views)
What method are you using to write to the file in the first place? Are you using NI-Vision by any chance?
If you write out pieces of a movie as separate files you can join them after the fact using something like VirtualDub.
(4,177 Views)
I am using NI Vsion.  I started out with AVI Create->AVI Write->AVI Close.  If the program stopped un-gracefully then the entire file was lost.
Next I went to something like AVI Create->AVI Close-> [AVI Open->AVI Write->AVI Close {Repeat Loop}]
and every permutation I could think of.  AVI Open seems to actually be "AI Open Read-Only"  because writing to a file opened with AVI Open only produced a blank stare from the program.
If there is a secrete way to get AVI open to open for appending that would be great to know.
If not, I suppose I could save each piece and then combine them with windows movie maker.  That is a fairly mesolithic solution, but at least it would allow us to (somewhat) walk around upright.
(4,163 Views)
Unfortunately I don't have NI-Vision. I asked the question since I suspected you might be using that. You may want to post this in the Machine Vision forum. Maybe someone there may be of more help.
(4,149 Views)
Hi anonamouse,
It looks like you already have your answer in the Vision forum but I just wanted to say that this is correct.  You can no directly append to a AVI in LabVIEW.
Link to other thread
Adam H
(4,133 Views)
