Repeat waveform by concatenation
Not to mention that you need more than 32-bits of address space to hold all those points, i.e. a Whole Lot of Memory.  Better run 64-bit LabVIEW on a 64-bit processor with a 64-bit OS and have at least 32GB of memory (maybe more, depending on the data type).  Sounds even more like you want to generate the waveform "as you go" ...
Bob Schor
Message 11 of 14
(1,395 Views)
At least that's verified why I did it the way I did. Thanks for the help guys, I hadn't realised just how large these waveforms were getting...
Message 12 of 14
(1,380 Views)
A "polite" way to say "Thanks for the help guys" is to click on the Kudo ("Star" indicator in lower right of post) symbol of the helpful post(s).  If you think one qualifies as a "Solution", you (and only you) can click "Accept as Solution".
Bob Schor
Message 13 of 14
(1,356 Views)
I had no idea, Kudos'd
Message 14 of 14
(1,349 Views)
