Replace a 2D Array in Original Array
I read N rows at a time from a file and I would like to replace a 2D array(Spike template) in original
array only in specific index read from a spike list index.
LV 8.6
Thanks for your help.
Attaching Vi and txt file.
I read N rows at a time from a file and I would like to replace a 2D array(Spike template) in original array only in specific index read from a spike list index.
LV 8.6
Message 1 of 8
(4,304 Views)
Hi wasabi,
why do you need a while loop?
19865i07F3ABDB1C07182B
Message 2 of 8
(4,290 Views)
because I need to read N rows at a time. For example, if I choose N = 100
I should replace the spike template from the 10-th to
19-th line of the first 100 rows of the original array, then I should replace the spike template from
160-th to 169-th of other 100 rpws of original array (from 100-th to 200-th row).
i hope it is clear.
Hi GerdW,
Because I need to read N rows at a time. For example, if I choose N = 100 I should replace the spike template from the 10-th to19-th line of the first 100 rows of the original array, then I should replace the spike template from 160-th to 169-th of other 100 rpws of original array (from 100-th to 200-th row).
i hope it is clear.
Message 3 of 8
(4,279 Views)
(This is a continuation of this thread. )
Your VI will not work. All that you're doing is replacing a subset in the current chunk, which gets thrown away in the next iteration of the loop. You are STILL ignoring the pre-allocation method I showed you in your original thread. I have no idea why you keep doing this.
Message 4 of 8
(4,263 Views)
I've tried this solution in my complete vi. It is attached. I read only N rows at a time, manipulate data and generate by using not allow regeneration.
All this to avoid memory full. I have tried with file of 170 MB and work fine
Now i want to replace a spike template(2D array) in specific index read from Spike list Index.
Hi smercurio,
To avoid memory full, I've tried this solution in my complete vi. It is attached. I read only N rows at a time, manipulate data and generate by using not allow regeneration.
I have tried with file of 170 MB and work fine.
Now i only want to replace a spike template(2D array) in original array only in specific index read from a spike list index.
thanks for helps!
Message 5 of 8
(4,254 Views)
anybody can help me?
i'll try again to explain problem if it is not clear.
I will appreciate any kind of help.
Message 6 of 8
(4,239 Views)
Please be aware that this community is made up mostly of volunteers, many of whom, like me, have full-time jobs. We cannot be on-call 24-hours a day. Please be patient.
I'm sorry, but I have no idea what this means.
General code comments:
  • Instead of using for-loops to create initializiation arrays, use Initialize Array function.
    For example, this:
    becomes this:
  • Do not insert extra blank spaces and new lines in enum values. If you want to format a list selection for a top-level VI, then use a different control at the top-level. Enum values should not have linefeeds and extra spaces just so they line up neatly when the text is centered.
Message 7 of 8
(4,228 Views)
Thank you very much for helps and advice.
I will try to explain better.
I want to make a new [(File lenght)*9] 2D array where i want to substitute a 10*9 2D Array (called Spike template) in Original Array (that i read from file I01.txt).
I would like to substituite this 2D array(called Spike template) starting from specific indexes.
This indexes are 10, 160, 2152, 2628......
So i would like a new array where first 9 elements is the same of original array. Then from 10-th to 19-th there
is 2D array(called Spike template) and then from 10-th to 159-th the same items of original array and then from 160-th to 169-th there is 2D array(called Spike template) and so also for other indexes until the file ends.
I hope it is clear enough.
Sorry for my bad english.
I've attached vi and txt file in previous posts.
Best regards
Message 8 of 8
(4,216 Views)
