Replace array subset for multiple index... problem!
Hi guys,
I need help with this vi, I get different index of array, which I would like change for another value on array. The problem is the vi only permit change one index... I would like replace several values from the several index on array. I have the index to replace and the values to put on this index. The problem is when I put 'build array' with constant out 'for loop', it creates 2D array with the changes, each row with one changed value... I would like to have the output on 1D array with all the changes values in  the differents index...
Can anyone help me??. Thanks.
I attached the file vi(lv7.1).
Mensaje editado por Fonsi
(3,295 Views)
Hi Fonsi,
The attatch is a modified vi. The turnels was changed to shift registers.
Xu
(3,285 Views)
Stupid me!! Thanks Xu!Smiley Wink
(3,280 Views)
