Replace quotient and Remainder with Scale by power 2
An algorithm like this might be of use: http://bknpk.no-ip.biz/my_web/divide_by_constnat/divide_by_constant.html
He shows what you'd have to do to divide by 10:
 x * (2^31+2)/10 >> 31
The above snippet worked for me, though I didn't do elaborate testing of any kind. If you know how many digits you'll need to support, you can create a look-up table to correlate input size to the "magic" constants you'll need for the above algorithm.
You'd have to code it up and try it out to be sure it really is more efficient than the Xilinx Coregen Divide though Smiley Happy
EDIT: Updated for clarity
Cheers!
TJ G
Message 11 of 12
(745 Views)
Ooops: The above doesn't work. I made some changes to pretty it up, and ended up breaking it. Try this one:
Cheers!
TJ G
Message 12 of 12
(728 Views)
