Replacement for 3562A
Looking for a way to get the 3562A data (PSD's etc) to a regular PC (instead of HP PC). Would Labview do this for me?
(3,329 Views)
Sure, it's done before.
A web-search told me that italian researchers used the 3562A in combination with LabVIEW:
http://topserver.mi.infn.it/noise/images/Oxford_rev.pdf
(3,329 Views)
Can't get the link to work?
(3,329 Views)
I cannot help you, the link worked 6 hours ago after a simple google search. You could re-try it later.
(3,329 Views)
I also did a google search and found a site with similar address and it didn't work either. It was also a pdf file. Weird??
(3,329 Views)
The link worked for me..? I'll attach the pdf file here. They seem to have communicated with the instruments through regular GPIB control.
(3,328 Views)
Just downloaded it, thanks!!!
(3,328 Views)
