Replacing elements in Producer Consumer Design template
Can the elements in the producer/consumer design template be replaced by VISA events?
For example can Obtain Queue be replaced by Enable Event
Enqueue be replaced by wait on event
dequeue be replaced by disable event
and release queue be replaced by discard events
I am still getting my grasp on the producer consumer design pattern. Perhaps an example VI that uses VISA read and Write with an event strucuture would an answer to a lot of my questions.
mhaque
(2,741 Views)
I personally have never tried to use those event VIs, but it is worth a try to test it out. If you are getting any errors, or having problems with it, reply to this post. Thanks,
(2,704 Views)
