Replacing old Out Port.vi for use on current PC
I am working on upgrading a .vi used for mass spectrometry.  It was set up on a windows 95 pc and it used the "out port.vi".  I have found a number of posts eluding to the fact there there is a simple new replacement for this outdated .vi.  However, I haven't been able to find a definitave answer.  So, what .vi can I use to replace the old out port.vi?
Soren
(3,063 Views)
Thank you.  That seems to address the issue directly.  I simply need out port old 6.x.vi.  Now, here is the sticky part.  We currently only have a license for 6i in our lab and we do not even have a site license for our department.  That is another issue entirely.  However, I want to run and develop the .vi we currently have without having to ask my advisor to pony up for another license.  He won't do it for starters.  I do have labview 7.1 student edition on my personal pc (labview course), but if I edited and saved the .vi in 7.1 - I wouldn't be able to read it in 6i.  Is there any workaround here?
(3,047 Views)
If you mean being able to directly edit a 7.1 saved VI in previous version, there's not a workaround.
If you want to develop a VI in version 7.1, and run it on machines without 7.1 installed, you can build an application/exe in 7.1 (if you have the professional version you'll have it, or you'll need the application builder addon, but check your student edition, it may come with it).  The client machines would need the LabVIEW Run-Time Engine, but that can be downloaded and installed from the web.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,020 Views)
