Replicating Scaled Time Domain Window (Hamming) and Auto Spectrum VI in MATLAB
Hi! I’m working on replicating some LabVIEW signal processing steps in MATLAB and had a question. Specifically, I’d like to understand the detailed implementation of the Scaled Time Domain Window VI (with Hamming) and the Auto Spectrum VI.
I know LabVIEW has built-in functions for FFT/PSD, but since the underlying code isn’t visible, I want to make sure I can match the results as closely as possible in MATLAB. Does anyone know where I can find documentation or a breakdown of the exact algorithms/constants used in these VIs, or has anyone already translated them into MATLAB before? Thank you in advance!
(1,186 Views)
Hi wji4,
Scaled Time Domain Window VI (Hamming)
This VI applies a window (like Hamming), scales it using the Coherent Gain, and calculates the Equivalent Noise Bandwidth (ENBW). You can find some documentation here: Scaled Time Domain Window VI
In MATLAB, you can replicate it like this:
w = hamming(N);
CG = sum(w)/N;
x_windowed = x .* w / CG;
ENBW = N * sum(w.^2) / (sum(w)^2);
Auto Spectrum VI
This VI computes the single-sided power spectral density (PSD) using FFT, scaled by sampling rate and signal length. You can find some documentation here: Auto Power Spectrum VI
MATLAB version:
xdft = fft(x_windowed);
xdft = xdft(1:N/2+1);
psdx = (1/(fs*N)) * abs(xdft).^2;
psdx(2:end-1) = 2*psdx(2:end-1);
If you're looking for how LabVIEW implements FFT and PSD internally, these docs go into detail:
Also, this Solved: Difference between LabVIEW FFT and Matlab FFT - NI Community discusses how others have done this in MATLAB — might be useful!
(1,102 Views)
Thank you FeSe!
(965 Views)
