Report Gen Toolkit MERGEBARCODE issue
I'm using the Report Generation Toolkit to create a printed label.
The toolkit is pulling data from an Excel worksheet and populating bookmark fields on a Word Template file.
Recently added a QR code to the label.
Following instructions from Microsoft here: https://support.microsoft.com/en-us/office/field-codes-mergebarcode-812fc43f-cb53-4782-8f9f-290ed08d...
Label is being created with the "curly brackets" and the MERGEBARCODE command still visible in the data field.
Instructions indicate that Ctrl+F9 must be used, and that typing the curly brackets will not work.
Is there a way to "toggle" the MS Word field codes in LabVIEW?
So far I have not found a way to do this.
Patrick Allen: FunctionalityUnlimited.ca
(3,460 Views)
Interesting.  My generation called {} "braces".  Of course, we called # "pound sign" and we didn't even have a term for @.  😉
Bill
CLD
(Mid-Level minion.)
(3,408 Views)
I don't have a way to do it directly, but I've had problems where the RGT would be a big pain, but a Word/Excel macro would be super simple.
In those instances, I just load the data into Word/Excel from LabVIEW, then call a macro from within LabVIEW. It's not as flexible of course, but it's a massive pain to do much advanced plotting or formatting from the RGT. Maybe you can trigger a macro to do it if you can't find a LabVIEW-native way.
(3,405 Views)
I think I may have found a way to do it.
Unfortunately I don't have the required version of MS Word installed on this PC.  Waiting to hear the results of testing.
Here's the MS documentation for MergeBarcode:
I concatenated the brackets, command, and switches with my data.  But the "field code" ended up in the field, not the barcode.
Found a post here:
https://forums.ni.com/t5/LabVIEW/How-to-update-fields-in-word/td-p/3207348
And then I found more MS documentation here:
https://docs.microsoft.com/en-us/office/vba/api/word.fields.toggleshowcodes
(3,388 Views)
Accepted by topic author pallen
The MergeBarcode method doesn't work and is poorly documented. Use the DisplayBarcode method instead. Here is an example using DisplayBarcode (Field type 99, MergeBarcode is 98).
Ben64
(3,318 Views)
Hi Ben,
Thanks for your reply.
Yesterday the client scripted a macro in the Word template file, and we are having LabVIEW call that macro to show the Field Codes.
Private Sub Show_QRCode()
    ActiveDocument.ActiveWindow.View.ShowFieldCodes = False
End Sub
If that does not work, I'll have something else to try now.  Thanks!
(3,308 Views)
Thanks Ben,
I ended up using DisplayBarcode (https://support.microsoft.com/en-us/office/field-codes-displaybarcode-6d81eade-762d-4b44-ae81-f9d3d9...
Concatenated the command and switches with my data and popped it into a Bookmark on the report template.  Then I call the macro in the template to toggle the field code.
(3,282 Views)
