Report Generation MS-Word always give error
Hi
I am using LV 2012 and MS Office 2010.
I am using report generation toolkit to have a customised output report.
When I specify output format as excel, I am able to get the desired result but when I specify output format as word, it always throws an error. I checked running the NI examples meant to give output in word but they all fail while the excel reports are perfect.
Please find attached an error code for one of the example Sample Report(word).vi
Please suggest the solution.
Manbir
(2,766 Views)
We need to see the code in order to say "Here is the error" or "Try doing it this way".  It also gives us something to try, ourselves.  Do you know how to make "snippets", which are .PNG "pictures" of your code that you can simply put into the message using Insert Image?  We can then drag this image into a LabVIEW Block Diagram, and voilà, working code!
BS
(2,717 Views)
