Report Generation Tool Kit
I have LabView7.1 and Labview8.0 installed in my pc.Recently i installed Report generation tool kit(version 1.0.1.0)
In the functions palette i couldnt able to see the Excel Specific VI sub palette and Word Specific VI sub palette.
Can u tell me what is the problem
Regards
Meenatchi
(3,194 Views)
hi meenatchi,
go to tool, in that select option....
in option go to control & function palettes. In that select advance in palette  mode.
After that u can see the word and excel vi  in ur function palette.
Ranjeeta
(3,190 Views)
You can not see it in either version?  Or has it been installed to the wrong version?  There has been postings on this board regarding how to get it to install to multiple versions.  I have not found tha to work.  I go in a 'manually' copy the VIs from add-ons, examples, and help to the latest version of LabVIEW that I have.  But if you look here you should find the help you need.
Paul
(3,188 Views)
