Report Generation Toolkit Error -41106
Hi
I have a problem with using the Report Generation Toolkit.
Creating my program the Toolkit worked fine and still does so with using the executable. Now I am creating an installer and it doesn´t work anymore, showing me error -41106.
Can anyone tell me why this is happening after creating my application.
I am using Labview 2018 professional and I am including the Labview 2018 Runtime.
I attached a little Demo with the same problem.
Best regards
Manuel
(3,120 Views)
Accepted by topic author ManuelElze
There is a KB article about this.  See if it helps you...
Error -41106 Using LabVIEW Report Generation Toolkit - National Instruments (ni.com)
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,091 Views)
I saw this article already. It doesn´t explain why it works with the executable and not with the application after the installation but the workaround works. I have to repair it almost every day.
Thanks for the quick reply
(3,058 Views)
