Report Generation Toolkit, Print Excel Report, LabVIEW Crash
when printing a report generated with the report generation toolkit for excel my build application crashes on our customers PC.
When I run this application on my PC it works fine.
The problem is the active X invoke node that trys to print the report but i cant get any error messages to find out where to locate the problem.
Maybe that there is a problem with the active X node or the Excel Version on the customers PC?
I use LabVIEW 2010 and Excel 2007 the customer has Excel 2003 SP 3.
I changed the report to generate it in Word where the Print_Report.vi fine on both PCs. But in Word Report there is called another active X invoke node to print the Report. So it seems for me that there really is a problem with the Print in Excel active X invoke node.
Mybe someon can help me in finding out whats the problem.
Greetings Daniel.
(3,821 Views)
Accepted by topic author Daniel_Leadec
Hi Daniel,
your behavior has been reported by others. For example:
Application Build Failure on Excel.Print Report call
http://forums.ni.com/t5/LabVIEW/Application-Build-Failure-on-Excel-Print-Report-call/m-p/1563242
So their workaround was to use Excel 2007 or 2010 instead of 2003. Is this working for your customer?
Best Regards,
Jan
(3,762 Views)
thanks a lot.
i got no negative message from our customer so i think this worked.
(3,686 Views)
