Report Generation Toolkit - Prints data from a previous report in Word
I am running an executable from the "system exec.vi" created with Labview 6.1. I am using the Report Generation toolkit vi's to create a report in Word that prints simple Title with test header and then appends a Table with measurement data. The problem is the measurement data in the table is from a previously printed report. This problem only exists when I Run the Report.exe from the "System Exec.vi". If I manually start the Report.exe in Windows or open in the Windows Commandline the correct data measurement data is printed in the report table. Any suggestions are appreciated. Thank You
(2,438 Views)
So far I havent been able to reproduce this on my computer. Could you post your code so that I can try and reproduce this issue?
Feroz P
(2,438 Views)
