Report Generation Toolkit and App Builder question..
I am in process of modifying my test code for writing my data to Excel. When I first developed the tests I did not have the Report Toolkit of Excel so I built the ActiveX VIs I needed. Now since I have upgraded to 7.1.1 with the MSOffice Toolkit I am rewriting my test code to use the toolkit VIs as it seems to work much better and faster then what I had done.
My question is this. Since I have my testcode distributed to multiple machines when I build my App, do I need to add every Dynamic VI within the toolkit to my App? if so is there and simple way to find exactly which dynamically called VIs are used within the toolkit VIs?
Jeff
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
(2,784 Views)
Greetings jdebuhr ,
I'm using LabView 7 and have the report generation toolkit, In the "Report Generation Toolkit User Guide.pdf" manual under the title Cearating stand alone applications you 'll find the names and the path of the required dynamic VIs to be included in your EXE file (using appliocation builder)
Check this manual.
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
(2,780 Views)
Thank you,
After I posted here it dawned on me to check that too..  I looked it up and found what I needed.. Now I need to build the app and try it as my source code seems to work well.
thanks again
Jeff
Jeff D.
(2,776 Views)
I have dealt with this same thing.  You can look in the toolkit vi's and see which the names of the vi's that get called by VI server.  Usually there are only about a dozen or so.
-Devin
I got 99 problems but 8.6 ain't one.
(2,774 Views)
