Report Generation Toolkit and Labview 8 ?
I currently have Labview 7.1 on my computer, and Labview 8.  I have installed the Report generation Toolkit 1.1.1, but when I try to open several of the excel and word vi's in labview 8, I get the error that "constants wired to case structures were changed to a hidden control to maintain compatibility with labview 7.1 and earlier".  And therefore the subvi's don't run.  Labview 7.1 doesn't have the toolkit installed, and I've even tried uninstalling 7.1 but nothing works.  How do I fix this?  Relinking to subvi hasn't work because it is not offered on any of the errored vi's or subvi's.  The broken wires are going into invoke node vi's, but I don't know how to fix them.  It doesn't allow me to rewire them.
(3,085 Views)
i had problems with upgrading from Trial Version LV 7 to LV 8 before, you might want to try to uninstall both LV 7 and LV 8, then reinstall LV 8 (it also helps if you restart your computer after you uninstall), it took me days to install LV 8 and make it works back then.. hope this'll help
(3,044 Views)
If you dont want to use it in LabView 7.1, Just make a mass compile with LabView8.0 on the directory of you package.
It could solve a lots of that kind of problem.
Be sure that you do net need it with your previous version.
Benoit
Benoit Séguin
Software Designer
(3,034 Views)
