Report Generation Toolkit to get a list of bookmarks in a Word Template and list of named range in excel work sheet
I want to write a VI to get the list of the bookmarks from a word document and get the list of the named range from a excel work sheet.
What VIs shall I use?
(4,011 Views)
I guess that there is no such functions in the toolkit. Because it's mostly for report generating, and not reading - reading of excel or word documents is quite limited...
Instead, you can check how to do it via ActiveX - moreover, toolkit itself uses ActiveX calls under the hood...
Sincerely, kosist90
(3,970 Views)
This is how you get a list of bookmark names in a Word document.  It would be similar for getting named ranges in Excel.
aputman
(3,952 Views)
Up !
It seems the snippet is not working...
Thanks !!
Bilsix
(360 Views)
