Report Generation: what determine row height?
When using the standard report generation vis, and I append a table, what determines the height of the rows? You can set the column width, but even down into all the vis, I don't see any way to control this.
This is in Labview 8.5.1
Message Edited by remenakb on 04-21-2008 12:53 PM
Brad Remenak
Certified LabVIEW Architect
(2,891 Views)
Hi remenakb,
i tried it and i think the row high depend on the "text data" length and the column width. If your text is longer than your column width, you will get a line break. I´m not sure if this was your question, but i hope it helps.
Mike
(2,873 Views)
I have a Zebra printer I am trying to print to and it seems like the row height is determined from just the text length. Even if the column width is plenty wide enough.  But if I send it to a regular Canon printer the table seems to print fine.
Brad Remenak
(2,860 Views)
