Report generation broken VIs in LV2009
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Utility\NIReport llb has 2 VIS "Get modified data" and "Set modified data" which are used by Report generation tool kit .
I installed LV2009 in which "Get modified data" and "Set modified data" are not present. When i installed report generation toolkit then, the report generation VIs in "LV2009\vi.lib\addons\_office" VIs are broken because they are search for above mentioned VIs.
Report generation 1.1.1 is what i am using.
Please suggest me a solution.
Muthuraman S
Message Edited by Muthuraman on 10-29-2009 01:10 AM
Muthuraman
(2,869 Views)
Reinstall the report generation toolkit again and check.
(2,862 Views)
Tried it many times.
I guess labVIEW 2009 doesnt support Report generation toolkit version less thatn 1.1.2.
Muthuraman
(2,859 Views)
yes might be, why don't you use the report generation toolkit along with the developer suite.
because same thing happened to me when i installed Report generation 1.1.1 with LabVIEW 8.6, then installed Version 1.1.2 which was along with developer suite.
Regards
VIsuman
(2,852 Views)
