Report generation microsoft tools missing in LV 8.5.1
I upgraded LabView from 8.5 to 8.5.1 and installed all of the toolkits. all of the toolkits seem to be working except for the report generation toolkit as the menu doesn't show any of the word or excel options. Has anyone else had this problem?
Message 1 of 9
(3,826 Views)
I've got the same trouble. The problem was solved with repairing. (Go to Control Panel->Software->National Instruments Software, then select NI Report GEneration Toolkit for Microsoft Office 1.1.2, and press "Repair" (You will need to insert CD with toolkit and select nisdist.id). After that all was screwed up for me.
best regards,
Andrey.
Message 2 of 9
(3,810 Views)
Hi there,
I had this problem too.  But fortunately others had posted their problems to various message boards and I was able to solve it easily.
I didn't try Andrey's method.  (It may be faster)
I went into Windows control panel --> Add/Remove Programs --> National Instruments.   When you select that, another menu opens so that you can select which component to remove.  I uninstalled the Report Generation Toolkit and then re-installed.   Worked just fine.
Patrick Allen: FunctionalityUnlimited.ca
Message 3 of 9
(3,792 Views)
Thanks for the replies, I found that uninstalling and re-installing fixed the problem.  The trick was working out how to uninstall individual toolkits.
Message 4 of 9
(3,757 Views)
Add report generation to menu in addons? I have unstalled and reinstalled several times but it will not show up as a menu item.  Tries to manually add you no luck.  It is installed but just doesn't show up in the menu pallet.
Path to VIs: C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\addons\_office
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 5 of 9
(3,536 Views)
Hello Matthew,
this toolkit will not show up as an additional palette. It replaces the standard NI Report palette. You cannot have both the standard NI Report and the Report toolkit side by side on one installation.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 6 of 9
(3,505 Views)
Hi Matthew,
Do you see Report Generation Toolkit in NI License Manager? Is it activated? Which version of LV do you have?
Message Edited by Andrew_E. on 02-03-2009 04:43 PM
RIO Embedded Hardware PSE
CompactRIO Developers Guide
Message 7 of 9
(3,480 Views)
Will check tongiht and post if it was pilot error or still hving issues.  Thanks everyone for their responses!
Matthew Fitzsimons
Message 8 of 9
(3,457 Views)
My bad.  It installed just fine but was looking in the wrong place.  Forgot that replaced a pallet and didn't add a new one.
Thanks!
Matt
Matthew Fitzsimons
Message 9 of 9
(3,439 Views)
