Report-generation vi problem
On a Windows XP system using the "Text Report Example" vi, the (read) report property node item "TextFont" (stdole.Font) at the beginning of the "Font Style" vi which is a part of the "Set Report Font" vi is returning this error:
"-1073741819 Unknown System Error in Font Style.vi->Set Report Font.vi->Easy Text Report.vi"
Any suggestions as to a cause and cure?
(2,847 Views)
This Knowledge Base from NI's website actually deals with this problem. The fix depends upon whether or not you have the Report Generation Toolkit for LabVIEW. There are fixes for whether or not you have the Toolkit. Hope this helps.
J.R. Allen
(2,847 Views)
