Report the X position at which an XY graph plot crosses a defined point on the Y axis using a cursor
I am looking to automatically display the X co-ordinate at which a plot crosses a predefined point on the Y axis. I believe that this could be done manually by using a cursor on the graph.
I am plotting the gain response of a low pass filter over a swept frequency range of 1000Hz and wish to determine the cut off frequency value (X axis) of the filter at the corresponding filter gain value of -3dB (Y axis). I am aware that I can create a cursor and manually drag it to the -3dB point and note the corresponding X value. However, I was wondering if there is a way that this can be performed automatically after each run with the corresponding value displayed in an indicator ?
That is to say that the Y value of the cursor be static and the X value follow the plot and report the X value at which it crosses the determined Y value.
Any help or advice that you could provide would be greatly appreciated.
I have included a copy of my VI below for clarity.
(3,424 Views)
Accepted by topic author DarrenOdea
1 subVI is missing. At the moment, i think you can just play with the property nodes of cursors to make them automatically go to the cut off frequency, and show the X value in an indicator. Here is an example:
here are the results
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
(3,413 Views)
Thanks Giuliano, much appreciated
(3,399 Views)
