Report using LV5.1
I would like to create a report-file (txt or Excel..) that contains
each input data and each output data in my VI.. How can I do?
Have you a G-prg for this??
(2,506 Views)
Hello SOLO,
I would recommend using the Report Generation Toolkit. It will allow you to write whatever data you want to Excel, and format it however you want, all from LabVIEW. If you do not have access to the toolkit, you can simply write your data to a spreadsheet file using the �Write to Spreadsheet File.vi�. There are examples that illustrate how to use the file i/o functions. Click on �Search Examples >> File I/O� then pick an example that best models what you want to do.
If none of these suggestions help, or if I�m not correctly understanding your issue, please reply with comments or answers to the discussion above and any additional information that may help, and I�ll be happy to look further into it.
Have a nice day!
Robert M
Application
s Engineer
Robert Mortensen
Software Engineer
(2,506 Views)
