Reports in Word
Is there a better way to add text to a Word Templates then Bookmarks? My problem is that some text I enter are limits that need to appear multiple times in the report but bookmarks can only be used in one spot.
Thanks for you input.
Paul
(2,673 Views)
Paul,
The only way to reference the location of text to be inserted into a Word document is with bookmarks, unless you are inserting the text at the end of the document. But one option might be to call the Append Report Text.vi multiple times, specifying a different bookmark for each location but the same text to be appended.
I hope this answers your question. Have a good one!
Tyler S.
(2,653 Views)
Thank you for your response. I was hoping that there was a way of using document variables or some type of Word Referencing but I'm not sure if there is such a thing. I found that filling bookmarks is slow (I am running on a 3GHz computer, 1G meg memory) and I would like to use as few as possible
Paul
(2,641 Views)
